Yesterday I burned a VCD of 44Minutes , (The VCD .dat is 808,213KB (Tmpgenc VCD Template , @ 2100kbps).
Today I was going to burn another 45 minute episode , which comes to 729MB (VCD Template @ 2100kbps) , but this time , Nero comes up with an "Insufficient Space .. to burn this compilation".
I'm pretty sure I have 800MB to burn in Mode 2 (which is why I up'd the bitrate to use more Cd space) , but it just isn't working.Is this some sort of Nero problem? I havn't tried uninstalling yet , but that's my next step.
Anyone have any similar problems?
Also , i've been out of the VCD loop for a while.Can someone just give me a "your right" on the 80min/800MB (Mode 2) thing I believe to be fact.
You're right. I think maybe Nero is trying to re-encode your mpeg because it isn't compliant VCD(1150kbps). Just a thougt.Originally Posted by VCDsMakeMoney
I have a bitrate calculator which gives the following as CD size when burning a VCD (mode 2):
74 mins = 748MB (765,797KB)
80 mins = 797MB (816,521KB)
These figures are theoretical - blank CDs vary and the VCD will have a minimal overhead for it's other files/folders.
Is Nero re-encoding your VCD?
Sounds unlikely as a re-encode to standard VCD bitrates would lower the video bitrate to 1150kb/s and make the VCD smaller.
Martin. -
I recieve the message when I start the burn.
It doesn't try to reencode the file.I burned a non compliant VCD (bitrate 2100kbps) before I tried to burn this one (which I included it's details in my first post).
It has to be the software.Nero burned a similar file before this one (the 44min 720MB or so file (800MB+ .dat) , which burned fine.This file is very similar in size and encoding scheme.Same media is being used.
I'm thinking the only thing I can do is re-install the latest version of Nero and hope for the best.Once I get back to that PC , i'll see if the reinstall resolves the issue. -
Are you sure you're not using 74 minute 650mb media? What is the exact size of the mpeg in question?
Avisynth error: insufficient memory
By olivier in forum EditingReplies: 8Last Post: 13th Feb 2018, 22:20 -
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 10:49 -
Insufficient hardware for software - advice needed
By johnlo1138 in forum EditingReplies: 4Last Post: 30th Mar 2010, 22:28 -
"Insufficient audio data or severe sync problem"
By carsskee in forum ffmpegX general discussionReplies: 2Last Post: 2nd Aug 2009, 18:31 -
New storage capacity
By GideonK in forum Latest Video NewsReplies: 30Last Post: 11th May 2009, 14:48
